roof motor problem solved, i think!!!
julsey36
I have been informed that a common problem with the Z4 roadster is the motor for the roof becoming immersed in water.
When told i thought id take a look, and uponopening the roof, i looked down the driver side and for sure there was a pool of water where the motor is, apperently there is a drain hole which beomes clogged by leafs and suh debris!
I got a metal BBQ skewer and had a poke around and found a hole which had become blocked! and with in miuntes it became unblocked!
So i hope this helps, i have a feeling i may have to check this on a reglar basis, i think a new motor could be very expensive and im told the labour is 4 hours just to remove the the roof!
jules
welcome if you havent been already.. lots of threads on this, it is an issue with the earlier cars.
there's another drain hole on the other side, look in the how-to for the way to fix, one side isn't as easy as the other but you're half way there!
