Roof motor- definitive list and prices
Hi buddy thanks for the info will definitely look into that tomorrow really appreciate the info.
Had it a weeek, bought it knowing the roof was stuck and I absolutely love it! Getting the roof down would be a massive bonus 😆
Thanks again buddy
Hi all,
I'm new to the Forum, and have found this thread very useful, as my roof motor has just died, despite being garage kept in my 5 years ownership, and only dry summer use.
It did sit outside for a couple of weeks back in May, so guess that's done for it... windows go down, roof un-clips, dead motor.
I therefore need to get the refurb and relocation sorted, as I'm not confident enough to have a try myself, and it looks like Number5 is the nearest person with the skills. I'm in Devon, so 1.5hrs from Bristol.
As I newbie I can't yet PM anyone, so if you're reading this, do get in touch so we can hopefully arrange something suitable.
Love my Z4... get a buzz every time I drive it, more so with the top down!!
Rich
Hi and welcome. I believe you need 3 posts to send a Pm so two more and you’re good. Post up a pic of your car and tell us a bit more about it, in two separate posts of course. 8)
Rich
Hi
Feel feee to give me a call at a sensible hour on
Zero 7707 662 six, double seven and we can discuss. :thumbsup:
Alan
Thanks for responding,
Will give you a buzz between 1.30 and 2.30 if that's convenient.
Speak soon!
Rich
Hi,
I see this is an old thread but I am also looking for someone who could re locate my roof motor (E85). At the moment it doesn't function but the motor does still make a noise and was sluggish for quite a while so I think it might just need hydraulic fluid.....perhaps? Might be a good time to check and also relocate before the Summer :-) I'm in Berkshire so anywhere I can travel to reasonably would be great, otherwise may travel much further afield. :-)
bugsy69 said:
Hi,
Welcome to the forum.
You have the choices of RBM at Hook, [ref]bigwinn[/ref] in Lincoln, [ref]Number5[/ref] in Bristol, and me in Norfolk.
There are others but further away.
If I've missed anyone my apologies.
If you had a fluid leak I would think it would fail pretty quick as they fire the fluid out fast.
The fact it was sluggish for a while would possibly suggest a failing hydraulic pump. Did it move better one way than the other?
Anyway, several choices and sources for parts should you need them. :thumbsup:
Thanks for the response, that's really helpful! It closes better than opening. I used to give it a hand, literally over my head and it would engage but then it wouldn't quite engage properly. Now it makes a noise but won't go back other than releasing the mechanism. Hook is close to me and Bristol Isn't too far. I looked but couldn't contact anyone, not sure if it's because I'm a new member? Is there a way to get contact numbers? Been a while since I was in Norfolk, used to go there every Month! Thanks.
Once you have 3 posts you can pm people, so if you just reply to say how amazingly nice and helpful I am, then you'll get your three. :D
The one's I've highlighted in bold will have received notification from that.
RBM are a business but very well thought of on here. You should be able to look them up.
bugsy69 said:
…..I looked but couldn't contact anyone, not sure if it's because I'm a new member? Is there a way to get contact numbers?
Here are all the details if you want to get hold of me
https://www.gumtree.com/p/car-part-accessories/bmw-z4-e85-roof-motor-relocation-repair/1378076429
Alan
Thanks Alan!
Turns out my Son's friend (ex BMW engineer) will do it and lives in Newbury but appreciate the advice on here.
Hi enuf zed / just signed up on the forum to see where you are in Norfolk I’m in Sudbury Suffolk but come up to Yarmouth once a month for work
My Zed’s roof has just stopped working
haven’t been driving her much lately and today the roof action was dead
Checked the parcel shelf was seated down
No sounds from the motor just the latches opening
Also couldn’t push the roof manually down even with the red pull switch out to disengage the hydraulics
Not sure if there is a blockage on the hydraulics
Did this once before and Had no issues with it before that no warning signs. Is it the motor do you reckon? Cheers
Hi there. Certainly sounds like a dead motor. Let me know when you’re up this way or can come over and we can get it sorted for you.
Hi zed
That’s great thanks - is likely to be in 3 weeks probably on a Wednesday- would 10th may possibly work?
Will confirm with you nearer the time
Are you near Yarmouth ?
BMUU said:
Hi zed
Nowhere near Yarmouth really. Attleborough on the A11 by Snetterton race circuit. It’s not a five minute job either. I think a specific trip may be easier if you can fit that in. 43 miles up through BSE and Thetford.
Just sent you a PM with my contact details.
In the meantime, do not try to force it open manually as you run the risk of bursting a pipe.
The fact it won't move is a good sign that the fluid lines are all still intact and creating a hydraulic lock at least.
l354uge said:
Hi, could you PM me you're details aswell?
Just picked up a z4 with a non-functioning roof
Hi. Whereabouts are you? No point coming to me if there’s someone closer
