Hi All,
I have been having trouble getting my roof to fold down correctly. I have relocated the motor and pump to the boot following a few guides found on the forum. I took the motor out and gave it a good clean and ran it in both directions, it works perfectly(it was working fine before cleaning). Hydraulic oil level is correct. I've checked all pipes, no kinks or leaks that I can find anywhere.
I bought the car in January, it had been parked up for the winter in a garage before I purchased it. Would the lack of movement for that period of time cause the roof canvas to stiffen up? Anyone ever have any similar problems and if so were you able to rectify them? The motor also needs a little help just after it unlatches, it will then take over and fold the roof down, I would say 90% of the way. If I then give it a little push down and press the button again it will lock itself in place.
Roof closes by itself with no issues whatsoever.
Would leaving the roof down during the night for a week help the situation at all?
I'm open to any suggestions you may have,
Thanks,
Stephen
Thanks,
Stephen
