bigwinn said:No that’s plenty
Over fill it and you’ll have issues potentially
If it’s struggling one way likelihood is the pump is on the way out
Best thing to do is swap the lines over, then gravity helps it on the way down and the good pump action drags it up
Undo the two 12mm bolts and swap them over as they sit
Don’t lose any of the brass washers
bigwinn said:Minimal
But worth having some on standby just in case you have a mare
Standard hydraulic jack oil and a syringe to get it in there
