Sgr74 said:
Dietcokeman said:
Ok so when it does this, does the roof eventually sink down to the correct position ( even if it doesn't lock ) ?
Yes. If I just put it down, the motor pulls it as far as it can then stops and the windows go up. You can physically see the roof rising a bit once the pressure of the motor is off. Once it's been driven for a while the roof kind of settles a bit. As in it goes down a bit more. It does sound like the fabric or hinge problem, I know, but nothing appears out of line.
It could be a hall sensor slightly out of position . Has the motor been relocated without the roof being removed ? If so it's possible that the sensor has been slightly dislodged and isn't quite in the right position.
This would make sense as when the roof stops and is slightly raised , the hall sensor thinks it's down completely and tells the roof module it's ok the raise the windows. As gravity takes place the weight of the folding roof pushes the rest of the hydraulic fluid back down the lines into the resoviour and the roof sinks to its normal position .
You could try the following, it may work ......
The roof is mounted at the front of the frame by two bolts each side of the rear of the door pillars. If you look just behind each door rear pillar on the inside there are two round plastic trim covers that cover these bolts.with the roof up but unlatched, Remove the trims and loosen ( do not remove ) the bolts . This will give you a small amount of play in the roof mounting , try moving it back or forward , tighten and retry the roof. This is sometimes enough to align the hall sensor . Not always but it's worth a try .
