no1beyondfan
Ewazix said:Was the motor making any noise at all? Did you have any lights on the actuation swich? this may help diagnosis,
Best eliminate the cheap options first,
- Check fuses in the glovebox, if a big item like the motor has been flooded it may well blow a fuse.
- Also make sure the rear roof drains are clear to drain the motor cavity and let things dry out properly, then try again (having returned the bypass cable/lever to it's functioning position, checked all micro switches are not damaged and the boot cover is properly in place)
If it's still not working after these checks you can panic, as it may be the main roof motor![]()
It does make a noise I think, but i will change the fuse and see if it works, the drains are clear (last checked couple months ago)
Thanks,
J
