Hi all, I've been posting about this on the Z4 owners Facebook page but thought I'd seek some advice here too.
For a long time I've had issues with water pooling in the boot, mainly behind the passenger side rear light. This must have been a longstanding issue, I now know why a previous owner drilled holes through the floor of the battery box after I filled them and then later discovered the battery sat in 4 inches of water!
I thought the leak would've been coming from the lights or maybe the bolts & clips on the rear quarter as is commonly found, but after a generous treatment of silicone the issue continued.
Cutting a long story short, I've now discovered the water is dripping into the boot from where the trim has been cut to relocate the roof motor into the boot (see pictures).
The photo taken from above shows a lovely puddle of water around the cable/hydraulic pipe entry point. Tracing the water marks, it appears as though rain is getting in around the roof frame (circled).
The rubber trim around the rear wing is not seated correctly, could this be a cause of the issue? Or is this not supposed to be the main seal, is there another seal between the roof membrane and frame that should be stopping water from getting in here?
In the short term I intend to put a patch piece in where the trim has been cut to at least stop water from getting into the boot, but in the long run if water in't supposed to be getting in here then I need to stop it.
