My turn for another roof fault.
So timeline....
1) Opened roof, deck went up, rear roof went on top of front roof... BONG
2) Checked fault codes, A691 Hall sensor, rear-end module open.
3) Ordered the correct part Hall Sensor.
4) Found the offending Hall Snsor, both wires had pulled out.
5) Replaced Hall Sensor.
6) Checked system, still not working.
7) Check fault codes, A694 Microswitch 'cowl panel reached'.
8) Managed to gain access to the microswitch above the driver seat. Microswitch operates and gives resistance reading for both positions, consistant with other microswitches.
9) Plugged back in and checked operation of roof. Press close button without operating microswitch and the LED stays RED, press the microswitch and press the close button and the LED goes GREEN. So to me this proves microswitch and wiring are OK.
10) Still got fault code A694, will not clear.
So, any help? Looks like it's going to have to go up to ZedShed if I can't find a solution soon.
Thanks for reading.
So timeline....
Thanks for reading.
