koolchris99 said:I'm not actually sure about that, you can see them from inside the car yes, but I'm not sure how the roof run off gets to the drain, i think as its a 2 layer roof the second layer is waterproof and the water runs off this into the drain?
I have no idea really, magic
bcworkz said:Rich-hill, it sounds like you're still applying water with the roof up? You will get very little water through the drains this way, it has to leak around the edge of the hood fabric under the sill. Slow at best.
Lower the roof, ensure you've identified the correct locations, and pour a whole bottle of water on each side. It will be quite obvious if the drains are working, as all the water should come out within several seconds. If not, clean as noted above.
gookah said:You may be too late then ..if the water has got above the soundproofing seal, then it will have filled the soundproofing and even cleaning the drain won't empty the water out of the canister that the motor sits in
andysat said:Was the cover in the wheel arch changed on the facelift zeds?-my cover seems to be all in one piece going under the car?-thanks
Cheers mate-just been out to double check mine -deffo one large section all one piece that goes under the car.Rich-hill said:andysat said:Was the cover in the wheel arch changed on the facelift zeds?-my cover seems to be all in one piece going under the car?-thanks
Mine is a facelift like yours and I still had the small wheel arch section. Was held on with 3 attachments
On the drivers side with the roof down ,get a length of mains electricaltabbie said:Any advice please on cleaning/checking drain holes are clear ideally without using a air compressor? I know I can pour water over the roof and check it drains but I worry this may damage the roof motor if the drain is blocked. Thanks![]()
Thank you maxmanmaxman said:On the drivers side with the roof down ,get a length of mains electricaltabbie said:Any advice please on cleaning/checking drain holes are clear ideally without using a air compressor? I know I can pour water over the roof and check it drains but I worry this may damage the roof motor if the drain is blocked. Thanks![]()
cable approx 30cm,split it and with a bit of poking around just in front of the hinge you will find the drain hole.
You can clear the drain hole on the passenger side with the same piece of wire ,but you will have to work from under the car.
I use a vacume cleaner to clear the crap out of the wells .Tape some small diameter pipe to the flexi pipe .Makes the dyson a bit grubby :?
The water either seeps through the "waterproof" fabric or around the edge where it attaches to the boot/wing cowling.Rich-hill said:Can anyone confirm how the water goes from roof to drain hole?
Does the water half to drop inside the car at any point?
bcworkz said:The water either seeps through the "waterproof" fabric or around the edge where it attaches to the boot/wing cowling.Rich-hill said:Can anyone confirm how the water goes from roof to drain hole?
Below the cowling is a trough to collect drips and move water towards the sump and drain holes. This trough is inside the car, though not easily visible.
If the drains were completely blocked, the sump could fill so much that it would overflow into the passenger compartment.
I tried your method of checking the drain holes at the weekend Maxman,but the cable would only go a short distance before I felt resistance. I tried both sides from the bottom of the drain holes and both sides where the same with the roof raised. Is this normal,do the drains narrow towards the top? I know the drains are clear as I ended up pouring water down them to check. Thanks for any advicetabbie said:Thank you maxmanmaxman said:On the drivers side with the roof down ,get a length of mains electricaltabbie said:Any advice please on cleaning/checking drain holes are clear ideally without using a air compressor? I know I can pour water over the roof and check it drains but I worry this may damage the roof motor if the drain is blocked. Thanks![]()
I use a vacume cleaner to clear the crap out of the wells .Tape some small diameter pipe to the flexi pipe .Makes the dyson a bit grubby :?:friends:
I found that my right side drain was blocked when I kept finding water in that side of the boot ,I thought at first it was the light seal until I took the boot lining out and saw the water running down. I don't think it can get into the passenger compartmentIf the drains were completely blocked, the sump could fill so much that it would overflow into the passenger compartment.
