roof drains...again...access
Max
Hi, Looks like I have got a blocked / partially drivers side drain. After really heavy rain again I am getting some water in the boot again. I unblocked the drains as best as I could during the summer, following as close as possible to the Zimmer fest url. (poked a wire up from underneath. ) However he stated that he could blast out the blockage with a compressor from above. How the hell can you do that, I can’t see the drain hole (a tiny gap). am I missing a trick.
Has anyone got any pictures on how you can access this from above?
get in boot,
take out top shelf, there are 4 clips,
put your hand in either side, you can access the drains..
failing that im sure if you just sit in the passenger seat and peer over your left shoulder you can see it.
http://z4-forum.com/forum/viewtopic.php?f=32&t=11615
or
http://68.230.199.103:8080/How%20to%20UnClog%20your%20SoftTop%20Drains.pdf
anyone fancy rehosting the pdf? or email me it at blue DOT forums AT gmail DOT com
this guys website is useless!
