Hi All,
Had previous fault code - Carly error code 00A692?
Microswitch, rear-end module closed, right.
Run for the last few months as a hard top version only - never lowered the roof in case it would not close again.
So based on number of roof faults listed on the forum I decided to purchase replacement switches and hall sensors.
Also purchased a selection of cables to enable replacement of all the switch cables that break over time.
This morning with the help of my son we replaced the two switched that operate the boot - to fix above code error
Followed one of the forum U-Tubes to perform the switch swap out.
all went well with no issues in switch removal and replacement.
When the roof close button pressed Roof sections move into position, then the boot moves into the closed position.
Windows close as expected. All GOOD.
Roof open button pressed - opens the boot, folds both roof sections into the boot then stops.
The boot wont fold back into the closed position?
Any suggestions?
Works ok when roof moves to close position
Does not work when roof moves to open position.
cheers
Jim.
Any suggestions?
cheers
Jim.
