Rolling road 3.0Si Coupe Vs Roadster
Interesting that only 2% difference, has Lee got any engine mods yet?
When was the last time you both did a oil & filter change?
If you doing an Z rolling road - I might bring my little 2ltr to the party
As far as I'm aware the engine is standard, I have serviced the car 2 times since Feb because I drive her hard. I did have the engine carbon cleaned in the summer but not convinced it did much. I'm slightly sceptical that the engine is stock because there is 20lb,ft more torque over BMW standard figures, Or it's just a really good one from the factory. 8)
Joycey said:
Steve84N said:
Something is off with those Coupe figures as it's supposedly making 250lb/ft but it should be more like 230lb/ft. Could be the conversion from wheel to flywheel which would imply it's making less horsepower. The roadster looks more accurate on that front.
Interesting thought, I dont know the last 10 year history so it could be a number of things. Both cars were tested within minutes of each other.
Are both cars running identical sized alloys & tyres ?
Always thought that bhp figures given by manufacturers were taken from the crank? I expected there to be a significant drop at the wheel (or does the rolling road read out allow for this?). If these figures are at the wheel then that's really impressive :thumbsup:
Yeah both are the same size and even same brands.
Oil changes can make a big difference, as I change my oil every 8K
Joycey said:
[post]1368574[/post] I'm slightly sceptical that the engine is stock because there is 20lb,ft more torque over BMW standard figures,
I call shenanigans, and temporarily revoke your bragging rights pending a stewards inquiry!
Seriously though, it's nice to see that BMW weren't ridiculously over boasting the figures in the brochures. Next up for me will be some mild tweaks (induction, exhaust & remap).
Will be looking for a remapping specialist, rather than ones that slaps on a generic download and can't prove what it does. I'll be back with another dyno for evidence of any improvement.
Great post OP. :thumbsup: Always interesting to compare similar specs and great that both cars are still pushing out close to the factory figures. :)
Gazhyde said:
I did an overlay, which isn't the easiest to make out but if you have good eyesight you'll be fine. Pretty impressive that there is only a 2% difference in BHP between the 2 cars after nearly 10 years of driving.
is the graph from dyno reading WHP or BHP?
im sure its already converted to bhp on the dyno chart as if it was WHP then the BHP would be around 290+ which isnt correct. When ive had dynos it normally says WHP. Test car in 4th gear usually best 1:1 ratio then dip clutch to measure drag then calculate.
:thumbsup:
So now I'm confused :cry:
What is the dyno run testing exactly? BHP at the wheel and then recalculating to give a crank shaft bhp?
Yes, they all do that.
Flywheel horsepower is a silly measure of power as what actually matters is how much reaches the wheels. I wish all manufacturers would quote WHP but then it'd expose how silly an idea it is to buy a 320d as an xdrive over 2WD. If they did you'd get a much better expectation of how cars compare with each other.
A dyno measures torque, hp is calculated:
HP = Torque X RPM / 5252
That's why the torque and hp lines always cross at 5252 rpm on the graph.
Rolling roads can only estimate flywheel horsepower, they can't actually measure it. Depending on the RR make/type, the estimates are made using a blend of known inertia (roller(s)), torque moment at the retarded, speed and "coast down loss". The dyno dynamics machine shown doesn't use coast down.
Wheel power isn't a certainty either, it's easily affected by numerous factors that can't be reliably quantified, you're right to call up tyres and gearing is a major curve ball with this type of rollers, but you'd expect that to be equal in this case. Wheel power is measured differently on different machines and you'd see much lower wheels figures on a MaHa LPS compared to this for example, with similar flywheel figures.
I regularly use engines dynos and various rolling roads and have never seen a reliable correlation from engine dyno to any rolling road. If you see a result you think is right, you smile, if you don't, you frown. A stopped clock is right twice a day!
Treat it as bit of fun and try not to obsess about the precision or provenance of results. :)
Joycey said:
Disca said:
At least I now know your Z4F alias Lee :D
Gimme a shout next time you head down and I'll bring the Z3 along!
Rumbled, We're going to organise a BMW Z day early spring. Keep an eye out :driving:
This was mine years ago at SRR, would be good to have another go next year
y3m0amvApGgng4MzfSfpbBjVkWfbjcr3Qn19CfZQBx1EmjzinR95p5iuzN1cPhwFvX8EMCg2HivROel5cMxEa1NnCbFPDTrS1UjaEPtx2X9y-H1X9b5OhGL9j34Ty2dMUQ8vvg84JyUD6838PaF1Y95fiSIeqBTsa4J83mHOEdCD-I
