TOMGREEN413 said:
Please can I ask what special tools you needed? It would be great to know, although l checked my engine yesterday as I too hadn't removed the engine cover since purchasing and found it all looked okay with nothing major leaking, but as preventative maintenance I'll replace the whole cover this summer, for now I've got my local garage replacing just the water pump and tank , stat housing etc. I have major plans for my car but I need to see what my friendly garage think of it before spending ££££.
As Brouse says, nothing too out of the ordinary - I just got caught short tool-wise a couple of times when going through the job!
I had normal 1/4 and 3/8 socket sets, but ended up needing to buy:
- 1/4" Torque Wrench 5-25Nm (to torque the valve cover bolts)
- Torx Socket Set (think I only needed an E8 and E10 for the job)
- 1/4" drive deep socket set (needed a deep 10mm socket for the two ground bolts)
- A 1/4" female - 3/8" male socket adapter. My torque wrench is a 1/4" but the E10 torx socket I needed to use for most the valve cover bolts is a 3/8"... difficult to find an adapter going that way around!! Amazon sells one for £4
- Some bent ring pliers to remove the metal spark plug tubes
So I did spend a little bit on tools (haven't added it up, but must be around the £50ish mark) - but I wasn't starting from a huge collection anyway!
And still very much quids in compared to asking a garage to do the work for me. The previous owner was quoted £410 just to replace the valve cover gasket!! Admittedly it was a main dealer, but pretty pleased I managed to install an entire good quality OEM Elring Valve cover for a hell of a lot less than that (around £145 for the cover including all new gaskets etc).
