I've noticed an oil leak coming from the the rear of the engine dripping onto the exhaust manifold, on closer inspection it's coming from the rocker cover gasket,
The gasket has been replaced recently by the previous owner so I was I bit stumped at why it would have failed already, so I decided to check the bolts, all of them are so loose i can almost turn them with my fingers anyway I've done them up snug for now as the tis guide says to do them handtight and not preload them but ista says to do that then torque them to 11nm.
Can anyone whose done this repair please advice on the correct procedure to tighten them ie the correct pattern and torque and any thoughts on why they would be that loose in the first place, maybe they were never tightened correctly or not checked again after initial installation?
