Looking like there is no leak, it is advised in BMW TIS that gasket sealant is used around the half moon shapes of the cover front and back where the gasket changes direction to provide a leak proof seal in these areas and the flat part at the front between the Vanos housing, the rest of the gasket requires no sealant. The ribs on the gasket all compress along the long flats and provides a number of barriers that prevent oil leaking. It is advisable to replace the round rubber seals that fit under the cover securing bolts as these harden with age and heat cycles and don't always provide a good seal which will be the cause of a vaccum leak and mess fuel trims up.
I have used Elring brand gaskets in the past and found them to be good. I did source the 15 round cover seals from BMW, I have seen complete gasket including the round 15 seals can be bought as a pack on ebay, not sure of the Brand.
