Roadster Solutions Windblocker Center Panel Removal
I just purchased a 2006 Z4. I need to remove the rear upper center console trim panel to connect an alarm sensor and BlueBus.
Can the acrylic center panel be removed to access the rear center console panel? Their website indicates it can.
I tried to remove it, but it is held tight by the brackets. Does it need more force/effort to remove?
Do I need to remove brackets? I didn't see any screws, so I assume they are attached to the rolliver hoops by 3M tape? Others have indicated this on the forum. If this is the case, I would need to remove the brackets and reinstall with new 3M tape?
Thanks in advance.
Mike
