javis20 said:I'll double check what the dealer set them to in the morning. Just had them installed today and disappointed with responsiveness.
javis20 said:Just switched from rft to non rft tires. Do i still inflate to the same tire pressures values listed on the door sill?
EssexZed said:Definitely don’t inflate to same pressure as RFT’s. I’m running at 34psi front, 36psi rear on my E89
lucasxdiniz said:My experience with new tyres suggests they require a fair few miles to scrub and feel like they should. Leaving the tyre shop I had a poo-poo moment when I floored the car on a straight and the car went side ways. Basically they had less grip than my very bold tyres just out of the tyre shop. After a 20 mile hoon the tyres felt a lot better, but only got full confidence on them after 150 miles or so. Just keep in mind they have a lot less grip initially so push your car accordingly; in the beginning of my first hoon I was understeering everywhere.
javis20 said:I should add that my car has the following tire sizes...
225/40 R18 in the front
255/35 R18 in the back
Dealer has them inflated to 36 in the front and 40 in the back.
I switched from Bridgestone Potenza RE960AS RFT's to Michelin Pilot Sport A/S 3+ tires and BMW dealer did a 4 wheel alignment.
My complaint is lack of steering response. Feels like the steering is detuned, almost like driving an estate wagon. However, the tires are quieter and ride is smoother, like an estate wagon.
Pbondar said:javis20 said:Just switched from rft to non rft tires. Do i still inflate to the same tire pressures values listed on the door sill?
What car, what size wheels / tyres, why tyres?
javis20 said:Pbondar said:javis20 said:Just switched from rft to non rft tires. Do i still inflate to the same tire pressures values listed on the door sill?
2011 E89 with M-Sport package. Switched from run flats to Michelin Pilot Sport A/S 3+
225/40ZR18 and 255/35ZR18
Pbondar said:...with an appropriate trade off..![]()
ronk said:Pbondar said:...with an appropriate trade off..![]()
I’m not sure what you mean?
Pbondar said:ronk said:Pbondar said:...with an appropriate trade off..![]()
Comfort, steering feel, ride etc
Pbondar said:Handling is such a complex subject..compounded by people’s preferences, biases and lack of comparative benchmarks plus where people spend their time in their cars..
So if you’re happy in the nicest sense who cares...
It’s clear that you can alter many attributes to change various aspects..
Obviously weight distribution isn’t so easy with the big heavy lump of the 35i with a lot of weight over / in front of the axle compared to the N20 engines cars..
The amount of power and how it affects the chassis are again complex variables..
When I started I was shocked at how ‘poor’ the car I have was..but I’ve changed wheels/tyres/arbs/dampers/steering parts/LSD and I’ve got used to it after 3 years and 15k miles of hard driving in unconstrained environments..
So I’m happy..I wouldn’t change it fior anything apart from maybe an Atacama Yellow 35 and based on past experience may regret it..
Maybe a 35i with lots of ‘my mods’ would be ok..certainly when I drove one two years ago I certainly didn’t like the handling one bit, the power was ok but it was more that there was too much power for the chassis rather than the joy of lots of power..I cane with £17.5k in my pocket, took it for a drive and went home underwhelmed..
But each to their own...
Rambling mode off..not sure what that has to do with tyre pressure..![]()
