Ladies and Gentlemen,
I can't believe that it took me 2 weeks to retrofit the nav sat wit x3 loom.
But finally, I did it! The main mistake was wrong wiring (issue with "-" cable). anyway, everything is fine now.
Thanks for your help, but finally, I have to found the right direction on my own and i was very concerned to
read all the myths and rumour how to install the system appropriately. let's give some more explanation:
- x3 loom works perfect
(a) just remove the 2 big black plugs
(b) splice directly behind the stereo the kbus, plus and the purple cable - no problem!!
(c) connect "-" cable to a audio "-" spot
(d) connect black/White wire to speedometer, cable pin 6
(e) blue/yellow cable seems not to be an issue at this stage
(f) yellow red and yellow brown cable to stereo, pin 5 and 11
finally, it could make sense to build an iso adapter to easy installation :.)
that's it!
- no need of navcoder etc. to code navi - inpa does this job perfectly!
- entire installation doesn't need a new headunit - also business navi headunit works, only an issue with the monitor off option - if you do select menu on the flap monitor and the cursor on the business headunit points on monitor off, both monitors are turned off - hence i used the original cid control
I love this mod though it costs me so much time due to my stupid mistake. and i ordered all devices twice
just to be sure not to have faulty ones. but it was me.
- by the way i also upgraded the cid radio and the air thing (dont know the english word) in black having the facelift look
if you need comprehensive support, don't hesitate to touch base. I'm now a nav pro expert since I've spend tons of hours in my car
