Hi all
I've had my E89 for over 3 years now and its still a joy to drive it (from what I remember as during lock-down its been hibernating under a cover!).
The one thing I always miss on the E89 I bought (used) is heated seats. My E89 has quite a lot of bells and whistles and the one thing I really would like in winter is the heated seats - I waited a while when I was looking buy but when this one came along at the right price I had to buy it - sadly although it has comfy sport seats it doesn't have heated/electrically operated seats.
I've been doing some digging re retrofitting and the following is what I think the state of play is re retrofitting:
- In my 2011 E89 I should not expect to find the wiring already present - so I will most probably need to fit a wiring loom
- Apart from the wiring loom the driver's and passenger seats each need a control box attached underneath (still zeroing in on the actual details)
- Of course I will need a new bank of switches that include the two heated seat switches (in my case I have the PDC switch as well as roof open and close)
I am not sure of the following:
- there is no retrofit kit available? (True?)
- there is no need for coding after fitting the heated seats kit? (True?) The wiring seems to need the K-bus though - so this must be wired in?
- Its not clear if there are seats/ wiring from another BME model that are a direct swap/fit?
I would be looking at getting a retrofit loom that was "close" to what I needed for another BMW model, using "generic" heating pads to fit into my existing seats - modifying the kit to use the BMW heated seat switches for the "OEM" look.
I am OK with most of the above but not sure on the bit using the BMW switches as I am unsure of how they operate at this stage.
So as you can see, still not there yet but a "work on progress".
If anyone has any pointers, links or knowhow I would gratefully receive it
Best
Best
