Retrofit extended lights
birdy_z4
Warwickshire
I’ve been following this thread and have everything done
https://z4-forum.com/forum/viewtopic.php?t=138025
It says to use pin 35 on x14260 footwell module, the being the left one as you look at it under the steering wheel
Mine though already has a pin 35 fitted
Anyone done this and is x14260 socket as said the left one?
https://www.bmwgm5.com/Footwell_Module_Connections.htm
Appreciate the help
It's the right side plug coupler for RHD and the left is shown in diagrams for LHD.
Photo taken from when I did mine :thumbsup:
EDIT** In the photo I've twisted it round 180° to show where the new wiring was :thumbsup:
Thanks Dave did you have to do any programming to get pin 35 working on the right socket, tried it no power ?
I honestly can't remember whether I checked it before I coded it, but the VO code for it is 563, which will need coding to the CAS and NFRM :thumbsup:
Thanks Dave I will give it a go if it ever stops raining
Worked a treat now have power just need to refit the inside back
B21 said:
birdy_z4 said:
B21 said:
Have you done the door handles ?
Only the internal for now
Bit more of a big ticket item…but..given your journey..do-able :thumbsup:
Thanks had the external handles off before and did contemplate doing it now and will revisit. Got an arm op next week which will stop the tinkering for a couple of months so out of time
