Mr Tidy said:Send him a begging pm - you never know!
Floydroid said:I completed this last night on my '04 Z4 3.0. Dead easy and worked a treat. 15min job in total. Bought my stalk from Soper's with forum discount. No loom required for mine.
Beware, the previous stalk is now out of production and unavailable from the dealers (it may be found secondhand) and this prompted me to do mine now, before they stop production of my version... I also found the dealer option to be cheaper than those on Ebay.
greg81 said:I just can't get used to the cruise stalk. Every time I go to use it I flash the driver in front of me
Mr Tidy said:greg81 wrote: ↑
I find it fine, but then I had the same thing on my 1 Series for over 6 years. Mind you when I first had that sometimes when I went to turn it off I would indicate left!
srhutch said:Previous stalk out of production?
What do you mean?
MalNCH said:Does the lower cowel, the bit you cut, come complety out so it's easy to work on? Without removing the steering wheel?
Jembo said:Yes, can be a PITA to remove sometimes... I had to walk down srhutch’s garden a couple of times while he resorted to ever more firmer levels of persuasion to release mine...
MalNCH said:Jembo said:Yes, can be a PITA to remove sometimes... I had to walk down srhutch’s garden a couple of times while he resorted to ever more firmer levels of persuasion to release mine...
Most come apart easily, others you just have to pull applying continuous pressure. It will come apart and so far I’ve had no breakages. They are small pins with an interference fit.
Sounds ominous.... :-o
Take the cowl off is the only way to be sureSteve67 said:
