Retro-fit parking sensors
peter2704 said:
Is there a knack to removing the bumper ? On your video it looks like the out clip has broken on it
No real knack, just be careful. That's the only clip I broke, but it doesn't affect anything :thumbsup:
I would just like to verify, using realOEM.com (https://www.realoem.com/bmw/enUS/showparts?id=LM71-EUR-01_2008_E89_BMW_Z4_35i&diagId=03_2033#66202157297) I dug up the following part numbers needed:
66202157297 as pdc retrofit kit
66209252638 pdc module
61319146645 cockpit switches
66206923000 some thingy that goes around the parking sensor
and 8x parking sensors themselves (I was thinking going aftermarket with sensors, as they are the most expensive part to get from BMW https://autodijelovi.net/senzor-pomoc-pri-parkiranju-fae-66069)
Is this everything or am I missing something? I can't find anywhere info if all the wiring is in the retrofit kit.
I will be also adding front and rear camera with Android MMI box at the same time while all the trims and bumpers are off
Thank You all for any help
今日本ではあおり運転をするものが出てきて皆バックルームミラーにカメラディスプレイをゴムで付けます。
私はZ4のロングノーズなのでフロントスポイラーが見えず困っていましたがこれを付けてから一時停止のラインやタイヤ止めなどにぶつけなくなりました。
リアも鮮明に写るため安心です。
