Hi everybody, this week I changed the rear brake pads together with a new sensor, car is the z4 e89 30i msport. The problem is I can get to the reset menu and select the rear brakes, then when reset comes up, I press and hold the BC button and I get the little spinning wheel (like a clock) but it does not do the job. I had 1800 miles left and it always keeps showing 1800 miles no matter how much I repeated the resetting procedure. I tried to search the forum but looks like everybody uses the procedure I mentioned above, to me it did not work. It did work wonders however when I changed the engine oil. Just not for the rear brake pads. Any magician out there?
