Reset tyre pressure light
boblez
 Formby
On the way into work this morning, lousy weather and feeling not too good myself, tyre pressure warning light came on. Cannot find anything in the the tyre and it they seem to be holding pressure. Im sure i found on here somewhere how to reset the light by pressing the button on the centre consol? Anyone remember how i do that?
Thanks!
You might want to check the pressure if you haven't already. To initialize the system:
1. Turn the ignition key to position 2. (Do not start the engine)
2. Press the tire (I mean tyre) looking button long enough for the yellow indicator lamp in the instrument cluster to light up for a few seconds.
3. Start the engine. After driving for a few minutes, the monitor stores the current inflation pressure as the target value.
If you have run flats it won't necessarily look obvious that one has lost pressure.
My light popped on a while ago, it looked like all tyres were holding pressure. However when I checked the pressures properly I discovered one had let some air out and had lost around 6 psi on the others. If you haven't already, I would double check your pressures before resetting the system just to be sure.
