enuff_zed said:Not exactly:Busterboo said:Yes, 10 is MoT failure.jenniferlouise said:I thought guidance was 10?
Tyres over ten years old at the time of test must be failed if they are on:
any front steered axle
any rear axle of a minibus with a single wheel fitment.
Incorrect only applies to PSV type vehicles…Uk government blog :headbang: :headbang: :headbang:
From 1 February 2021 Construction and Use Regulations will not allow tyres aged over 10 years old to be used on the front steered axles of HGVs, buses, coaches or all single wheels fitted to a minibus (9 to 16 passenger seats). So, if used it will mean a dangerous fail at annual test and a prohibition.
If inspected at a DVSA enforcement check, tyres aged over 10 years old found on these positions will be considered dangerous and attract an ‘S’ marked immediate prohibition notice.
It will also be a requirement for the manufacturer’s date code to be legible on all tyres fitted to HGVs, trailers over 3.5 tonnes, buses, coaches and minibuses. If a tyre is a retread then the manufacturer date is taken from when the retread was carried out.
