S skelters Veteran Greenock, Scotland Aug 30, 2023 #2 Bilstien B12 Pro Kit - Eibach Springs and Bistien shocks. Change the top mounts to Purple Powerflex at the same time. The Bilstien kit will lower the car 30mm lower than Sport Suspension. Whatever you get change the springs and top mounts at the same time. Also get a Hunter Alignment done. It'll be like driving a new car!
Rockhopper Senior member Mansfield Site Supporter Aug 30, 2023 #3 Or if you want to keep it close to stock but a bit comfier then Bilstein B4’s.
Z Zedebee Veteran North Hampshire Aug 30, 2023 #4 Or stock and get Sachs. Not expensive if you get them from somewhere like Autodoc, not BMW. Skelters’ is probably the best solution, but I could not justify spending that kind of money on a £5k car.
