Deepseaskateboard Senior member Nov 17, 2015 #21 Yeah, it must have been a manufacturing fault with the one I purchased. The search continues!
M Markos_Z4 Member The Netherlands Nov 29, 2015 #22 n52 cilinderhead tick: use 200 ml ATF oil mixed with your oil ! problem solved
S Smartbear Lifer a barn in Somerset Nov 29, 2015 #23 Markos_Z4 said: n52 cilinderhead tick: use 200 ml ATF oil mixed with your oil ! problem solved Click to expand... I've heard of people adding this to their engine oil because of its high detergent properties, should give you a nice clean engine internally Regards
