Replacement bulb
ARE you talking about the H8 halo which is mega cheap or the innermost lamp? (Trick question here for those in the know)
It's the light on the right hand side which has gone out. Not entriely sure which one it is but think it is the Halo light.
The halo/angel light circles are powered by a single H8 bulb which is cheap and easy to fit.
Put your cars sidelights on and this will illuminate the halos if they’re working without putting on the xenons.
Looks like the halo as mentioned. You should have sign on the dash, press left indicator stalk in, scroll to check control, press end in again and should give you the error code. Stick that into google and you should then know which it is. I had a halo ring bulb go on mine, cheap OEM bulb off amazon and really easy to fit. Good luck :thumbsup:
