pvr said:
Starter is about 30cm from the battery yep.
I thought as the battery was being aired with the bonnet open that nothing would linger around it. I wasn’t aware of the need to let it rest
You were just unlucky. You had one of those '1 in a million' scenarios where everything was aligned for this to happen.
The hydrogen to air volume mix only needs to be above 4% for there to be a chance for it to ignite from a spark.
I'd say if the ctek is faulty it would have happened whilst charging. However the price of a new charger compared to the value of your car collection is quite low, so I'd replace it.
I handle more batteries than the average person but have never had one explode, I have heard of it happening to people locally. I even charge upto 8 batteries at a time, all daisy chained together, off a single charger, which would likely raise eyebrows, but it's been good for 20 years.
The only battery incident we've had on site was with the bosses wife's car. She'd had this ctek style battery charger for a very long time. It connected onto the battery with crocodile clips. Everytime she took it off the battery it would rotate the same way so that the wires were getting twisted.
Eventually the insulation got old and cracked, whilst she was about to disconnect the wires with the charger in her hand, the final twist made the wires connect. As the wires were still connected to the battery they instantly got red hot, she freaked out and just dumped the lot and ran. Luckily I was close by and she got my attention asking for help. I ran to the car, which was now bellowing black smoke and unclipped the wires.
It caused quite a lot of damage, as the car was a 911 with the battery just below the windscreen in the front (obviously) boot. It melted all the plastics and the carpet along with front bumper. Could have been worse as the car was in the garage, with another car next it and with it connected to the house.
It's quite a scary situation because when it happens the panicking stops you thinking straight. Nothing will stop it until you break the circuit. It's similar to the those diesel runaway videos you see on YouTube. As a spectator watching you can think of a few ways to shut the engine down but when it's happening to you I can understand why everyone is standing watching it bellowing out smoke
All chargers now have an inline fuse on the positive as close as possible to the battery terminal or if they have a fancy split connector block then a fuse is placed there.
