Here's what I learnt while doing this job:
The plugs under the console:
Plug 1: 12V Cigarette lighter: remove by squeezing side clips and gently easing it out.
Plug 2: White with magenta guard. From memory, you lift the guard with screw driver, then push under guard to lift white lever:
Plug 3: This grey plug is clipped to the drive tunnel with a plastic arrowhead that goes in easy and doesn’t like to be pulled out. A large flat-blade screw driver could be used to lift it off the tunnel by sliding it under and turning the blade to lift it from the centre.
Plug 4: From memory, this has either clips on the side or a handle that pivots and, as it rotates, it ejects or inserts the plug..
Plug 5: Lift the magenta guard with a small screwdriver:
Then push inside with the small screwdriver to lift the clip that holds it together:
Hope this helps other people who don't want to have to resort to experimentation.
Cheers All!
Cheers All!
No fault codes or anything else that I'm aware of
