Hey guys I'm considering the Remus axleback and would like to fit it myself if possible.
I've done a bit of looksies under the car and on realoem but want to check if I've missed anything!
- From what I've found, the rear section is only attached with 2 clamp sleeves to the mid section which look pretty straight forward?
- The muffler mounts wriggle the rubber off or can I unbolt the brackets, then transfer off the car (I'm thinking the latter)?
- In terms of access, it looks like only the left brace and the reinforcement plate need to be removed?
- Finally, would there be enough room just lifting the rear up on 2 stands as opposed to getting the car up on all 4 corners? Or maybe up on the left side with 2 stands?!!
Thanks!
Thanks!
