I need to replace the upper spring pads on the rear of my E85.
I've removed the rear springs before, which wasn't a big job at all but left the car wonky. By this i mean one side was higher than the other by about 15mm. This (from what i've read) is because i did them by jacking the car up one side at a time, whereas the correct way is to remove and replace both sides at the same time so the bushes are both reset to the same level.
Does this make sense, and if so once i get the car up on jack stands at the back, is there any particular method to making sure the car doesn't end up higher on one side than the other or should it just correct itself?
I've got 19s and lowering springs so i simply don't have the margin of error for one side to be even 5/10mm higher than the other.
If it's going to be a ball ache to get it perfect i might just take it to the garage but thought i'd ask on here first.
Thanks.
Paul.
Thanks.
Paul.
