Removing Driver’s side/ offside vent
ProfCJJ
I am trying to remove the drivers side/ offside vent to fit a P3 dash gauge I bought in the US. As far as I can tell the piece of trim under the vent itself somehow “pops off”/ is persuaded to unclip and then the vent is held in by two screws.
I have tried (gently) to get the trim off but have not met with much success - I have not prodded too hard in order not to break clips etc. - is there a trick to getting this trim off intact please?
Many thanks for any pointers.
The trim under the vent that goes around the headlight switch is held in place with a screw.
To access the screw a bit of trim must be removed from the end of the dash next to the trim you want to remove.
Thanks. I guess that means it’s the end panel that somehow can be prised off then I remove the light-switch panel screw then the vent.
I’ll take a look. Appreciated 👍
