Ant said:god what a ballache
removed all the scotch locks in the end and put them in the choc blocks, only one that is hassle doing that is the thick red/black/yellow wire, total pain in the hoop to fit it and the gaptech wire into the block.
amount of times i had it working and had to pull the console out as it stopped when i'd pushed it all back in...
soldering if you have the skill for it is prob the way to go.
nb67 said:Ant said:god what a ballache
I have various size blocks and used a slightly larger one for the thicker wire. You'll be glad you used blocks after the scotchlok nightmare!
Yes, but at 249 Euros for the Smarttop, I'll take my chances with the scotchloks, solder, chocolate blocks or whatever it takes to get the RCH installed :lol:owm said:In this aspect the Smarttop module is superior as it is plug and play, no splicing, soldering or cutting of wires and it mounts cleanly near the the roof controller module
Any1else said:I read in one of the threads on here that the soldering iron should be heated up and then unplugged when using in the car - something to do with earthing.
Don't really understand this (and not something that I have ever done).
Any kind, knowledgeable person like to enlighten me?
