JetBlackZ said:Trex said:JetBlackZ - 4 snows on a Z4 makes a world of difference. Go with the Axxis pads. No brake dust. While working on the pads, paint the calipers and also the rotor hat. Use a VHT paint for both.[/qoute]
Thanks, would you recommend the OEM rotors or would I be okay with a pair of EBC USR932 Ultimax Rotors or Power Slot rotors?
The reason I am contemplating between the two is because the OEM are so darn expensive on Amazon they are $213 each not per side and the EBC are only $125 per side, and I usually replace the rotors and pads when I redo the brakes.
In the past I have bought Brembo rotors thinking they would be really good for my 3 series but they warped really quick and only lasted a very short time.
PhilDZ4 said:Yes, you are missing something.
20ducks said:Good point there AlanL. Do remember that his next duty station will most likely be in an area where he won't even be allowed to wear his uniform or drive a Z4. :evil: Odds are it will be cold...real cold.![]()
It is also your first.PhilDZ4 said:Dammmittt said:PhilDZ4 said:Yes, you are missing something.
I know its against your nature, but would you care to fill me in?![]()
In all seriousness, it has to do with density... nitrogen is "bigger" than air... it doesn't leak out of the tire as quickly....You're right, however, that's the last explanatory post for me in 2008.
20ducks said:AlanL, a region that has 4 months of extended daylight comes to mind.
AlanL said:Aebous - the moderators should have pointed out that you are not permitted to post in threads addressing winter driving conditions since you have no clue what "winter" is
Your transgression will likely be overlooked this time given that the topic shift addressed serious stopping instead of cold weather traction :roll:
In all seriousness, it has to do with density... nitrogen is "bigger" th14.0067.an air... it doesn't leak out of the tire as quickly....You're right, however, that's the last explanatory post for me in 2008.
20ducks said:PhilDZ4, what ever you do, don't ask him what time it is.... :zzzz:
