Ed Doe said::lol: this is too funny.
The power tails off top end because there is a soft limiter on the n52.
enuff_zed said:Well I'm glad I gave you a laugh![]()
However I was alluding more to the fact that I've never seen a power curve that keeps rising. They always drop off what we used to call the 'powerband' at some point.
So I was thinking that, by the time you hit the rev limiter you should realistically be another gear up anyway (unless you're on a track perhaps).
I was considering that the OP my have been aiming for a magical figure without paying due attention to the physical limits of his engine with regard to rpm. Not knowing his mechanical/engineering knowledge level, I was hoping to at least make him think about the potential for damaging his engine.
I concede that my comment may have been a little short of qualifying detail, for which I apologise.
The fact that it gave you a moment of amusement does, in some way, alleviate my concerns.
:wink:![]()
Ed Doe said:enuff_zed said:Well I'm glad I gave you a laugh![]()
:wink:![]()
I mean in light of your 'further qualifying detail' it makes a little more sense :roll:
However raising the limiter will not necessarily put the car 'out of the powerband' - you'll have to go quite a lot higher in the revs for that to be the case - remember torque and hp cross at 5250 rpm, so your torque can continue to reduce but the revs increasing still means you're getting good hp... Its very different to a diesel remember, where its quite common to be making a lot less horsepower at the top end than midrange - purely because the revs aren't rising as fast as the torque is falling - so the multiplication of the two means power is dropping... If that makes any sense?
mmm-five said:(and a bitter period I had with insurer Adrian Fux means I'll neither use nor recommend them again).
Most definitely intentional.enuff_zed said:Ha ha! Was the omission of the 'L' from Adrian Flux a freudian slip or intentional. Either way it's subtle and very funny.![]()
mr wilks said:300bhp without add ons is never gonna happen to your N52 E86.
If you really need the extra bhp it's S54 time.
Supercharge itR60BBA said:They don’t even make 265 from factory![]()
As stated, if you want 300bhp either get an M or the N54 E89.
mmm-five said:Supercharge itR60BBA said:They don’t even make 265 from factory![]()
As stated, if you want 300bhp either get an M or the N54 E89.![]()
enuff_zed said:I think to some extent we are violently agreeing![]()
My main concern was that the OP was searching for a 'bar talk' figure but not giving due consideration to the extra stresses on the engine.
Hopefully that is not the case.
In the real world the torque is a much more useful tool than the bhp anyway. If you can't quickly overtake the slowcoach in front you will never find the open road to check out the top end bhp.![]()
the pub figure result is exactly what I was worried about!
