Reluctant sale due to health issues, if interested please msg me.
BMW Z4 3.0I SE Auto, DOR 25/09/2004, 47K miles, colour black, CURRENTLY WRAPPED IN PASSION RED METALLIC AVERY DENNISON by Custom Hub of Wickford (September 2023).
Engine M54, Red Leather/Oregon traum-rot, M Sport Suspension, M Sport Seats, Electric Seats, Driver seat with 3 memory positions, Heated Seats Driver and Passenger, Satnav, original cd dash radio with original dash flip screen, 6 disc cd changer, all working as they should.
Roof motor repositioned in boot, drain plugs removed.
Extensive car file
MOTs back to 2008 to current due date of 18/12/2026, Service history back to 2014.
Usual age related marks for a 22 year old car.
Private plate will be removed.
£4,750
Replaced in my ownership, no expenses spared:-
04/04/26 Norfolk Zed Rescue fitted new valve cover gasket set Elring, headlight washer fuse removed as not used, pipe leak capped-off (can be reversed/fixed and fuse returned)
26/10/25 Norfolk Zed Rescue replaced rear coil springs both sides Suplex
10/09/25 Norfolk Zed Rescue replace front suspension both sides, top mounts Sachs, dampers Sachs, bump stops Febi Bilstein, anti roll bar drop links Stark, coil springs Suplex, knuckle bolts genuine BMW. Replace rear suspension both sides, top mounts Bilstein, dampers Sachs, bump stops dust covers Febi Bilstein
31/08/25 starter motor replaced Bosch
17/08/25 Norfolk Zed Rescue fitted new front brake discs and pads Brembo, fitted new front brake calipers, fitted osf wheel speed sensor, bleed brake system/test drive.
Aug 25 new tyre's - Front Goodyear Eagle F1 Asymmetric 3 tyre's 225/40 R18 92Y / Rear Nankang AS2 tyre's 255/35 R18 94Y XL tyres
23/05/25 drivers side BMW window regulator fitted by Bennetts of South Woodham Ferrers
25/04/25 After market headlights fitted by Bennetts of South Woodham Ferrers
09/04/25 x2 dsc dynamic stability control brake pressure sensors fitted by Holt Motor Services Hockley
19/07/24 inlet housing pipe replaced by Holt Motor Services Hockley
05/10/23 BMW transmission switch with 2 year gtee fitted by Holt Motor Services Hockley
18/09/23 Custom Hub full Car wrap
19/08/23 both boot struts replaced
14/08/23 PB Lock & Auto Keys supplied 2 new keys to support 1 original key
10/08/23 Autoglass windscreen and rubber surround replaced, windscreen wipper deep arch scratch and stone chips in drivers line of sight.
15/07/23 AA replaced faulty cylinder 2 coil
July 23 B pillar airbag sensor right side replaced together with ABS DSC YAW speed rotational sensor replaced.
Extensive car file
£4,750
