The torque looks mighty impressive, slightly better than a stock 35is (336ft lb v 332ft lb). What were your initial thoughts on your drive back home?
biZ4rreMids said:The torque looks mighty impressive, slightly better than a stock 35is (336ft lb v 332ft lb). What were your initial thoughts on your drive back home?
R.E92 said:That's a good result. Hopefully it drives OK at part throttle.
Wastegate tuning is pretty tricky, they are controlled in 2 parts, a standard base map that acts as a starting point for the wastegate and then a PID loop that adds or removes depending on how far under or over the target boost the pressure is. Getting a bigger turbo fully dialled in is tricky because the base map and the PID loop both need completely reworking. Usually takes a lot of road testing.
