colb said:Still looking like low resistance on that right airbag according to those codes, since the wiring is intact and clean connections next step would be to switch out the airbag for a known working one, scrap yard should come up with a suitable replacement with same part number as yours.replacement is fitted and then the code cleared see if the code returns. If it returns then delve into the airbag module connection and check the plug and pins for cleanliness that end. Use a voltmeter set to 200ohms and put the leads on the wires that come from the right airbag and see what resistance number you get that end. I do know the pretensioners must have less than 1.0 ohm recent test on a pair of those I made showed up as 0.4 and 0.5 which was in spec, not sure what you should have on an actual airbag at the moment.
Just found this thread which may be of interest https://www.m3post.com/forums/showthread.php?t=1498270
Seems their problem was broken tabs in the airbag plug causing low resitance, double check yours for damage.
They mention 2 x 2.7Ohm resistors were put in place of the airbag and that took the warning light off so their airbag needed that resistance to satisfy the main module. I invested in a small resistance diagnostic test meter a few week back but not used it in anger yet. It can be connected to the wiring and a range of resistance adjusted until the right setting turns the light off on the dash with an ignition cycle. Using this would at least prove the wiring is ok and the actual airbag is at fault which a normal volt meter can't tell you.
https://www.ebay.co.uk/itm/223475405476
Reading your edit- a temporary fix is to bridge the socket with resistors?
Don’t get me wrong I’d prefer it working but to get the light gone that’s an option?
The tabs are ok I checked them
