Thank you markplant, I will have a look, it'll make a nice Christmas pressy for meHalfords advance is just over 100 , lifetime warranty
I think that a torque wrench, no matter how 'out of whack' is useful as you do get the 'click' which helps not to overtighten stuff too much, especially for clueless types like me.In short, with a modicum of common sense and engineering nous it is sometimes just as easy to judge it by hand.
Yes I amI agree with Martin. Unless you have them calibrated every five minutes, they are only an approximation, so I would get the cheapest you can find.
I have noticed that the 'cheapest' end of the market; ie screwfix, tool station, machine mart, draper, silverline, etc are all exactly the same tools just badged differently.
Presumably @MikeyH you are looking for a 1/2" drive from around 50nm up?
Yes I’ve been looking at that one and it seems a good price, it won’t get much use so a bit daft spending a fortune on one. The only time I ever used one back in the day was for tightening cylinder head nuts, everything else was by feel.My father-in-law gave me a torque wrench that he used in the 80s and hasn't been calibrated for years. I bought a cheapish Draper one from Amazon, and it clicks at EXACTLY the same settings, leading me to believe that they are both pretty accurate.
Even if it's not perfect, it's surely better than just TAF?
Good advice, thank you.I bought a 1/2" torque wrench (Halfords standard job in a grey blow molded case) in about 1997 when I started tinkering with cars. It mostly got used as a breaker bar since I didn't know such things existed at the time. Once, in a fit of excitement, I stuck it in the vice, hung a bucket of rocks on the end and waved mathematics at it to find that it was pretty accurate. Many years later I bought a 3/8" job too.
In the thick end of 30 years I've rarely used them, the chief use for the 1/2" drive possibly to calibrate my arm so I got an idea of how much force I should throw at things. I've done suspension arms, wheel nuts, brakes galore, inlet manifolds, top end engine stuff (rockers, valve covers etc) - almost all by feel and never killed myself even slightly, had anything come adrift and (almost never) broken anything. I've also been able to undo them again as I've not gorilla'd them on either. The only times I've really used either in anger have been:
Two things to know about torque wrenches which makes them utterly useless in most hands:
- Tighten to X Nm + 90 degree joints
- Glow plugs (both undoing and doing up - they're something like 8 or 10 Nm and they will snap if abused.)
- Rebuilding a Smart car engine. A lot of that comes under the first bullet point really but there were various hollow banjo bolts that absolutely would not take even the slightest over-tightening without sheering off - though that rather makes me think they were badly spec'd. Oil sprayers I was glad to do with the 3/8" one for obvious reasons.
- When it goes click, the fastener isn't correctly torqued. You have merely reached the tightening torque and it needs to be held until the fastener has stopped moving. Since people hear a click and immediately release, it ain't properly tightened.
- If you are wont to slather copper grease on everything (ghod save me from the lunatics that put it on wheel bolts), all bets are off. This affects the whole process and the "correct" torque is now meaningless.
Please explain how the fastener will keep turning after the click? If you apply any turning moment at all then you will be increasing the tightness. The click occurs when the wrench reaches the correct torque. You seem to imply that somehow there is energy stored inside the wrench that keeps turning the fastener without further input from the user?I bought a 1/2" torque wrench (Halfords standard job in a grey blow molded case) in about 1997 when I started tinkering with cars. It mostly got used as a breaker bar since I didn't know such things existed at the time. Once, in a fit of excitement, I stuck it in the vice, hung a bucket of rocks on the end and waved mathematics at it to find that it was pretty accurate. Many years later I bought a 3/8" job too.
I think there may be a slight misunderstanding there?It's something I heard along the way which made sense so it stuck with me. The fastener is only properly tight when it stops moving with the correct torque applied; the torque wrench tells you that you're applying the correct torque, not that the fastener has finished overcoming whatever friction/stiction/other[1] there is that allows it to keep creeping round. You're not increasing the force but maintaining it. I suppose a good example would be some form of deformable sealing ring (maybe a copper washer would be a good example.) It gets squeezed at whatever force is applied by, say, 50Nm but it takes a finite time for it to finish its non-elastic deformation and crush properly. Apply the 50Nm and immediately take it away again and it's not tightened down properly.
That's how I understand it anyway. It always amuses me to see tyre places wave torque wrenches at wheels going as fast as they can. Say the bolt is 90% tight they don't give it anywhere near enough time to overcome stiction and start moving before they're off to the next.
[1] I am not a tribologist
