I'm in Canada and I don't recall any discussion here about the Recall Campaign # 2017 - 470.
It appears to affect vehicles equipped with a 6 cylinder N52K or N52T engines.
It has been going on for quite a while, starting in Nov 2017 with a notification of fault, replacement delayed due to part shortage.
Parts became available in August 2018 and when I inquired to book a service appointment was told that the next available appointment was in February 2019 (!!!) That's 6 months even though parts were apparently available.
The Service Person recommended that as a February appointment would probably be problematic, because the Zed would most likely be in winter storage, and if I did choose to drive in February, snow and slush could complicate road conditions on such a low clearance car.
Her recommendation was to wait til February to book an appointment in the Spring. I did that today and am scheduled for April 15 20019.
I have no problems or disputes with my dealership. I can only speak very positively about their treatment of any concern I have had and have provided me with many incentives / benefits of dealing with them. I'm posting this to discover if any Z4 Forumsters are aware of this recall / issue.
According to the recall letter this is "What could happen" ?
The PVC blow-by heater incorporates a heating element, which is designed to prevent the PVC valve from freezing in cold ambient temperatures, due to condensation that can form in the PVC system during engine operation. The subject PVC blow-by heater could overheat due to component production inconsistencies, which could result in a short in the heating element, caused by a build up of moisture in the associated electrical components.
If the PVC blow-by heater overheats, the surrounding plastics could melt and potentially cause a fire, which could increase the risk of injury and / or damage to property.
This potential overheating of the PVC blow-by heater typically occurs while the vehicle is being driven, however it is possible that this could also occur after the vehicle has been parked, with the engine turned off. (The next sentence is underlined ) For this reason, BMW recommends parking your vehicle outdoors until the recall repair has been performed.
If the PVC blow-by heater fails the driver will, in most cases, be informed by illumination of a warning telltale in the instrument cluster.
So fellow Z4 Formsters, at least consider this as a FYI to be aware of. If you hear of any fellow enthusiasts that have experienced this condition, please pass on this information. It does appear to be more prevalent in colder climates, but Canada isn't that much more extreme than many areas covered by the Forum. ie Cold enough to snow ! Maybe a PVC blow-by heater is one of those local BMW design accommodations limited to cars destined for certain geographical areas ? I don't know. But I wasn't prepared for such a long delay for this repair. And I wasn't prepared to leave my Zed parked outside for the better part of 21 months.
Please note that any BMW model with the previously identified N52 engines are included in this recall.
I hope this helps
Cheers from Canada
Bumpy
I hope this helps
Cheers from Canada
Bumpy
