Hello, i wonder if someone can advise on a rear suspension refresh. I have now started acquiring parts for this, which will be carried out by a local indie. The parts I have so far are:
· Front & rear subframe bushes (Powerflex - Shore 70A)
· Replacement rear control arms
· Replacement rear droplinks
· Rear Trailing arm bushes (polybush)
· Replacement upper and lower bushes on the trailing arm (with upper ball joint)
I will also be fitting KW v1 coilovers at the same time.
I realise I will be creating additional stiffness, but do want to avoid adding too much NVH. My questions are:
1. Will I require new adjustable drop links for the front (if fitting KWs). The ones at the front were only replaced 6 moths ago.
2. Is there any merit in fitting adjustable control arms at the rear?
3. Is there any merit in replacing the diff bushes?
4. Would it be preferable to fit polybushes in the control arms, ARBs and drop links?
5. Lastly, the top mounts (F/R) were replaced 24 months ago. Is there any merit in replacing/upgrading these?
Many thanks
Many thanks
