ihadablackdog
I know its been covered before, but can someone tell me if the following is likely to be covered under the AUC warranty:
1. Left rear light cluster....sometimes there is condensation in the indicator strip, but not always. However, there is a ladybird (yes!) in one of the red compartments above it.
2. Right rear light cluster...pretty much constant condensation in the indicator strip. Doesn't look like any water sloshing about etc, but the condensation doesn't seem to clear.
Would 1&2, or one or the other, be covered for replacement under the AUC warranty? It's been suggested that they should be fixed by the supplying dealer...who says all BMW lights get condensation....
and will let water in :thumbsdown: the worst bit about the lights is that the lense over time starts to fatigue and will crack and split where it is glued onto the main body of the light unit :thumbsdown:
