A
Anonymous
Guest
Ok, just started stripping down the rear end to tidy up the years of decay and ive hit a snag trying to remove the rear lower arms. On the advice of my local BMW garage, the intention is to the replace the bushes at both ends but annoyingly the bolt is just a bit too long to take out in situ. So, can i remove the half shaft by taking out the torx bolts or do i have to remove the main nut in the hub end and extract the shaft from the diff ie on a splined shaft? Cheers, ratty..
