Rear differential part numbers
Jamie25
Gloucestershire
I'm researching fitting an Lsd to my M54, 2003 E85.
I'm considering a blackline one from Matt Lewis Racing as I can't really afford other options. Their website and an exchange of emails suggests the one they would supply me with is for a 188L diff.
I'm under the impression that my car has a 188k diff.
Real OEM shows a part number of 33107514129 for my car.
The sticker on the diff reads as follows ;
8903032114770009
7514128/E2637R.3.07
I believe this gives a part number (33107514128?) one less than Real OEM suggests.
Sorry for the long winded post, but I've two thoughts.
Which type of 188 diff do I have?
Is the part number suggested on Real OEM just an updated version of my actual part number, being only one number out?
Just be sure it's a 188 diff and not a 168, I'd be starting with that. Guess work gets expensive.
I'm comfortable it's not a 168. But I don't really know the difference between the 188k and 188l. It might just be the finned back plate.
Hi Jamie , I am planning to buy a Matt Lewis Racing LSD.
Is it a good product? Would you buy it again?
I'm afraid my research didn't get any further. I nearly bought this diff but in the end I couldn't be sure it was right. The idea kind of fizzled out with money and time being a little tight with a young family.
That said, if you do go for it if be interested to know how you get on and your thoughts on if it transforms the driving experience. I've a niggling thought I'll l do it eventually as there are no other cars out there that interest me for even twice the price.
Good luck in any event.
I'm not 100% about this but I think the K refers to the output shaft style. K bolts onto the driveshafts. Earlier BMW diffs had the driveshaft splined end insert directly into the diff.
In my opinion LSD is mandatory on a roadster . It really makes the difference in certain situations.
It helps to exits faster from tight turns.
Two years ago I was able to reach with my 1993 Miata the top on Bernina Pass in Swiss during a massive snow storm. I had 10 years old snow tires.
The LSD was crucial , my friends with open diff had to stop and use wheel chains.
Instead of looking at the part number for the complete differential (or more specifically, complete unit inc housing), look at the category "Final drive, gasket set"
The gasket & rear cover of the differential unit have a description of the differential they are suitable for - i.e. for my Z4 it's "TYP 188K".
I got this info from RacingDiffs - https://www.youtube.com/watch?v=Tedvr4gLYeM
