I've been working on a rear brake upgrade for the E85/6 as I'm experiencing high pad wear and temps on track.
I've managed to come up with two solutions.
1, using the 320mm X3 disc, 330i calipers/carriers, a 5mm disc spacer and some weld-in brake show adaptors from VYS Garage to solve the move to a 185mm handbrake
Untitled by Damien Bower, on Flickr
2, a M135i setup using the 345mm rear disc which works with a 160mm handbrake and the two piston caliper. You just need to trim the backing plate and use some £40 adaptors from eBay to reduce the thread size to M10. Dead easy and appears to work perfectly. Custom lines are also required, once they arrive I'll do a full walk through/write up.
Untitled by Damien Bower, on Flickr2, a M135i setup using the 345mm rear disc which works with a 160mm handbrake and the two piston caliper. You just need to trim the backing plate and use some £40 adaptors from eBay to reduce the thread size to M10. Dead easy and appears to work perfectly. Custom lines are also required, once they arrive I'll do a full walk through/write up.
