Rear Brake Hoses
DMC63
Active member
 London
I'm changing the flexible brake hoses. I've got the fronts. The rears have 2 flexible hoses on each side. One connecting to the caliper the other at the swinging arm to allow for the movement. I have the rear hoses that connect to the calipers.
I can't seem to find the hoses for the swinging arm connection.
I'm holding off from going to BMW until I've exhausted all aftermarket options. Any pointers to aftermarket hoses is greatly appreciated.
Hi if you google the part numbers from realoem you should find them all over the place . Check the schematic but I think you are referring to part 5 Brake hose - left 34306774341 & Brake hose - right 34306774342 ? and I found prices varied hugely, but like anything you tend to get what you pay for :thumbsup:
https://www.realoem.com/bmw/enUS/showparts?id=BT32-EUR-02-2004-E85-BMW-Z4_25i&diagId=34_1288
Yep, I think that's the hose. I'll have a look around for a decent one.
Thanks for your help.
You can get custom lines made up quite cheaply - even get one hose that replaces all three.
£25 a corner.
Chris_D said:
£25 a corner.
From where?
https://auto.helperformance.com/custom-brake-hose
Will make up to your specs.
More info here - https://z4-forum.com/forum/viewtopic.php?f=2&t=79253
