P plenty Active member Aug 8, 2022 #1 Anyone know if this will work with the rear ball joints on our cars? https://www.astatools.co.uk/product/a-9055/
D Davz Active member Wellington, Shropshire Aug 12, 2022 #2 Looks more like a drift to remove a bearing or bush. Ball joints usually require a splitter tool.
P plenty Active member Aug 12, 2022 #3 Thank you - the rear ball joints are pressed into te trailing arm, like a bush.
J Jakg Member Suffolk Aug 12, 2022 #4 Without any measurements it's very tricky for anyone to say. I would (/ did) get one of the big sets with different sized bits. Or you can use a ball joint press and some sockets...
