Rattle when switching off the engine??
Peter P
Hey Guys,
I've noticed an annoying rattle noise when I switch off my engine (car is a 3.0i 2003 model with 65K on the clock)?? Also seem to get a clicking/clunking in second gear sometimes?
Not sure when the clutch was replaced (may never have been come to think of it?!), but can anyone suggest anything I should look at?
It's due a service in October with Mid-Kent Technical, so hopefully they will pick up on anything out of place.
Thanks in advance for your help. :thumbsup:
Cheers.
Pete :)
if depressing the clutch stops the rattle then my advice is to just ignore it; it's a very common issue unless you want to waste money replacing the clutch springs :)
Either Lay Shaft, Input Shaft, DMF, or Clutch release bearing - All in all the 3.0SI N52 has a notoriously rattle clutch/gearbox either pulling off at slow speeds and/or stopping the engine with the clutch pedal raised, its generally nothing to worry about.
domsz4 said:
i get this too. what is it? the clutch release bearing... i thought these were on a hydraulic clutch
Hydraulic or not, moving parts still need bearings. While hydraulic, it's not the fancy hydraulic collar you're thinking of. It's a master slave/cylinder affair that operates a traditional lever which pushes the release bearing to remove the clutch plate pressure against the disc and flywheel.
Even with the hydraulic collar, there is a release bearing built into the mechanism.
