E Exotica Member Jul 31, 2009 #1 Noticed a rattle from the engine (3.0) as soon as i turn the engine off, last for a second or so and for sure a mechanical rattle. Any ideas ? Thank you
J jan_tekin Senior member Kent Jul 31, 2009 #2 Try turning the engine off with the clutch down and see if that helps
E Exotica Member Aug 1, 2009 #4 With the clutch in there is no noise. So what is that rattle, is it normal?
I IK. Senior member Wiltshire Aug 1, 2009 #6 Yes, this is normal. Not sure why it does it, so can't ease your mind, but it is normal.
S Smokin Senior member Chapel Hill, NC Aug 1, 2009 #8 It rattles 'cause there are a couple counter-rotating shafts in there. Space is tight and they rattle. There are several threads on the issue. It's fine.
